3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
3DS Max 2018 cant modify model, as if its frozen
6 REPLIES 6
1029 Views, 6 Replies
Hello =)!
I have a problem. I made new model and saved it[Save As...]. Now, When I open[Open...] it to make a some changes, I can`t do anything, as if the object is frozen, but it is possible to select the vertices or edges of the object, as well as its polygons (You can select them, but You can`t do anything with them) - extrude, move, scale, rotate - all these functions is frozen. The last time I saved the model as usually - [Save As...].
3Ds Max - 2018.4
How to fix it?
@Anonymous
Your post subject line has been edited by @hagen.deloss : As if the object is frozen - Ican`t modify the form of the model
6 REPLIES 6
hagen.deloss
Hi @Anonymous,
Thanks for posting your question, lets try to figure this issue out together! I have encountered this multiple times, with various causes.
So to get the basic possible causes out of the way, can you hit the spacebar and start moving the object again? (spacebar turns on the "selection lock toggle" found on the bottom ribbon below the timeline.Screenshot (13)_LI.jpg
Since you can still select parts of the polygon object, its obviously not frozen....so lets explore some less common causes for the issue.
I went searching around and ran across this thread, the last post may be helpful. They suggest going to your motion tab and seeing if there are any constraints applied to your object! That can be found under command panel>motion>parameters and check the XYZ parameters
If none of the above helps, feel free to attach your scene file and I can take a look!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
Hello @Anonymous
I wanted to check back and see if my earlier post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process
Please hit the Accept as Solution button if the post solves your issue or answers your question.
Hagen Deloss
I created an animation(*.gif), I hope it helps in the solution =). Thank You, for answ. =)!
GIF-Animation - 960x540\366Mb
https://drive.google.com/open?id=1zQ4Cnu29v0XaK0JbbXIUCYlEyHtYNFwx
hagen.deloss
@Anonymous,
That sounds super frustrating! There is a possibility you have set your default controller to a different mode. To check you can navigate from the command panel to the motion tab, and click parameters (with your object selected).
If it doesn't display xyz movement scale or rotation, then you will need to restore it to its default settings.
If that still doesnt work, we can take that a step farther, and reset 3DS Max's settings overall, here is an article documenting how to do that.
Hagen Deloss
in reply to: hagen.deloss
You just saved my model -<...restore it to its default settings...> - working =)! Thumbs UP and Thank You =), Have a Nice Day!
hagen.deloss
@Anonymous,
So happy I could help! I'm sure this will happen to me down the road so extra bonus that we found out the solution together.
It would be awesome if you could mark my solution so that others in the community can benefit from the knowledge!
Kind regards,
Hagen Deloss
