3ds max 2017, edges disappear in Poly modeling
jkorngold
jkorngold
hey there, havin gthis issue where my edges disappear when i go into poly mode, for edges, faces etc... please see image.
any idea whats up?
Replies (7)
keyner.chavarria
Hi jkorngold,
Have you tried to reset 3ds max to default?
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Resett...
Keyner Chavarria
Autodesk Maya Specialist
jkorngold
Heya, i have done.
The problem appears when looking at the object from the backside.
quick example is turning a 4x4 division Plane to Editable poly. all disappears when looking at it on a solid color background, i noticed the edges to still be there when i set the background to gradient. *note that im using the Light UI setup, been using 3ds max for 20 years (renascent.nl) now at google. Cheers!
dominique.bouthillette
Autodesk Support
Autodesk Support
Hi @jkorngold,
Could you submit the file you added the image of? I'd like to take a look at it and see what might be going on there.
Thanks!
Please Accept as Solution if a reply has helped resolved the issue or answered your question, to help others in the community.
Kindest regards,
Dominique Bouthillette
Principal Specialist, Industry Support & Escalation
Entertainment & Media Solutions
jkorngold
here you go, thanx!
Autodesk Support
Autodesk Support
Thanks so much for the files @jkorngold!
Here's a link to the Screencast video I made so you can can work with your edges and polys again. It seems that was just an issue of turning off "Backface Cull" in the Object Properties of the model. 😃
Let me know if this helps!
Kindest regards,
jkorngold
Excellent, probably ticked that by accident.
Have a great day!
Autodesk Support
Autodesk Support
No worries at all. 😄
If this solution has helped and you wouldn't mind, please hit the Accept as Solution button. It would be much appreciated as it will help other users in the future.
Thanks again and have a great day as well!
Kindest regards,
