voronoi style objects
This video shows how to do it. It is not in english but the process is quite clear:
https://www.youtube.com/watch?v=XThYBC2pnnI
A quick example done with the method with Max included
@Anonymous thanks for sharing that, how would you turn that into a solid? I exported it as an stl and it is not watertight.
Do you mean the model I posted? It should be.
There is always the chance there is some accidental gap error because the complexity of the geometry.
You can go to border mode and drag select to find open geometry and close it manually. Or use Xview.
