Viewport camera problem
Message 1 of 9
Whenever I try and select an object or a vertex, poly, etc, the camera just flies away and I always have to press Z to come back to the model, anyone knows what's the problem? Thanks in advance!
https://gyazo.com/da59ee4462d8f0c6bad9081bbb07037d
Replies (8)
Message 2 of 9
miledrizk
Is this happening in all files or just this one?
If you open a new fresh max file and create a simple object near the origin does it work normally?
If the previous test works then you need to check if your objects are too far from the origin,
And try to moving them so they are around 0,0,0
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Message 3 of 9
They're indeed close to 0,0,0 and yeah it only is this scene, thought I pressed something because I saw people with the same problem, but no solution
Message 4 of 9
miledrizk
It's a bit strange, anyway,
Maybe you can open a new Max file and use Merge to bring all your objects,
And see what happens.
miledrizk@gmail.com
Message 5 of 9
Still doesn't work, tried restarting my PC and moving the shapes to another save, same bug.
Message 6 of 9
Fadhil_Farook
Can you upload the file here? Let's see if this is local to your PC only or is global!
Message 7 of 9
Yeah sure, here it is, if nothing works I'll try and moving to 3ds max 2019 see if it does anything
Message 8 of 9
Fadhil_Farook
I've opened the file and tested. It's not happening on mine though. I am using Max 2019. But I saved a copy as Max 2017. Try opening this using Max 2018.
Message 9 of 9
miledrizk
It happened when I opened it, it's a bug in the ViewCube.
To deal with this issue you have three ways:
1- Press the letter P to work in the perspective view instead of the Orthographic view.
2- If you want to keep working in the Orthographic view, press the letter P to switch to Perspective,
Then Press the letter U to switch back to Orthographic view, and this time the problem will go away.
3- Simply disable the ViewCube by clicking the "+" sign near the Viewports name, find the ViewCube
And uncheck the option:  Show the ViewCube.
miledrizk@gmail.com
