Unable to see selected polygons
Hello Everyone,
I am experiensing this issue with 3ds max design 2015 SP2. (File attached)
Once I select a polygon or edge on the "green" ceiling plane I can't see them! I can see the vertexes, once I am in vertex mode but edges and polygon faces are not indicated in red as normal.
If I am to copy this shape as a copy, the problem will not be persisting.
If I make an instance, then I am carrying over the same issues as described.
This issue seams to happen with instanced objects.
In the file attached I created 12 boxes as instances, once in edit poly I can't see selected edges or faces. I also created 12 boxes as copies I have no problems seeing the edges and faces.
I can't attach the .max file for some reason, so please find attached a link to dropbox download -
https://www.dropbox.com/s/t3gs1h4eg8rp3qz/test.max?dl=0
I would appreciate your help, as this is very frustrating!
By the way,
this issue does not happen with 3ds max Design 2014.
Kind Regards,
Ingnore this!
Service pack 3 resolved this issue!!!! What a relief!!
