taking an object out of another object
There used to be a feature where you could select an object to be "operand A" and another thing to be "operand B" and the final result would be operand B is invisible and there is an operand B shaped hole in operand A. Does this feature still exist? How do I use it?
bob.bernstein
You are looking for boolean or pro-boolean compound objects.
leeminardi
Older version of Max had one Boolean function.  Now there are two; ProBoolean and Boolean.  You can find them under Create, Geometry, Compound Options.  I find the ProBoolean choice more intuitive and it produces better results.
lee.minardi
