Splines into cross sections
maveJ7EGB
maveJ7EGB
Hello all!
I need Your help. I stuck with converting cross sections into surfaces. Here on the screen shot is the result of my "work". That was done as follows: I created lines from given cross sections of fuselage, they are different in shape, but I created them with equal number of vertices, then I used cross sections modifier and got edges, but they are going with different angles and I'm not happy with the result after applying surface modifier. Is there a way to make a fuselage from cross sections other way? With better final result?
maveJ7EGB
I guess I found an answer to my questions and to my approach. I will look into U loft surfacing.
