Splines dissappear when using editable poly modifer.
Just curious why when adding editable poly modifier to the stack for my custom shape why everything disappears. I tried a similar experiment with an ngon and things seemed to work fine with an ngon but not my custom shape.
domo.spaji
Splines must be closed and without intersections in same spline.
If you apply extrude modifier you will see "bad" splines without capping polygons...
