simple hole in a 2d drawing
anselmo3
Observer Observer
anselmo3
Observer
Observer
hello I can not find an answer !!
Briefly, I draw a 2D circle and a square inside, now I want to extrude, leaving the inner square empty, like a "donut"
how you do?
thank you all
PROH
Hi. There are more ways to do this. Here's one:
1) In Top-view draw a circle and a square. The mustn't overlap or touch each other, and make sure they are drawn at the same level.
2) Select the circle and put a "Spline modifier" on top of it (or convert it to a spline via right click > convert to.... ).
3) In the spline modifier roll out you press "Attach" and pick the square. Now the two shapes are part of the same spline.
4) Put an "Extrude modifier" on top of the spline, adjust the hight, cap both ends, and you should have your "donut".
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
anselmo3
Observer
Observer
works!
thanks
