Show all materials in viewport
Hello forum,
i have a quick question. I have imported 300 objects with texture materials into 3ds max 2016. I want to she the texture of these meshes in the viewport. Each mesh has a unique material. So 300 meshes 300 materials. I want to show these materials in viewport. I am trying to find a way to skip having to pick each material and press the button that says "show material in viewport" 300 times.
Is there a way to automate this process or make it happen for all materials in scene simultaneously?
Thank you very much for your help
Michael FOuntouklis
rendermaster
try Show Material in Viewport Script : http://www.scriptspot.com/bobo/mxs3/smiv/SMIV_23.ms
I attached the compiled version here, in case you don't know how to compile script.
-Go to Scripting Menu/Tab, then select Run script and point to the location of the downloaded script
-Go to Customize Menu then select Customized user Interface, then Toolbar and look for Category - Bobo's Tool , select and drag the toolbar "Show Maps in Viewports" in your preferred toolbar location.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
I couldn't get it to work. I guess maybe the script does not understand Corona Materials?
It fails in line 70, apparently because "m_array" is undefined.
