- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to copy the top section of an object (rocket model) to create a separate object (crew capsule).
It will only allow me to do this with vertices selected, but all I end up with is a cloud of unconnected vertices.
Is there a different technique that I should be using to get the new object that I obviously want? If not, is there a way to get back the edges that weren't copied over to the new object?
If neither of the above options are possible, would the proper procedure be to just copy the whole object and chop off the parts that I don't want?
