Semi-dark objects
Semi-dark objects
gurhany
Semi-dark objects
gurhany
Hello.Some objects in my scene are semi-shaded even though there is no light in the scene.When I apply normal modifier, they turn black. When I add material, it does not change.I use max 2021. Thanks.
dbtITadmin
Hi there, try adding a 'weighted normals' modifier to the object and collapse the stack.
May have to play around with the setting in there but that usually works for me
gurhany
Yes, I did not add a normal, but when I add normal on it again.The problem was solved, as soon as I encountered this situation after that, it is normal + normal + smooth. Thank you for your attention.
