Selection method
Selection method
Selection method
Hi!
I need a specific kind of selection method. Think that I have a helix with several turns and turns are relatively close to eachother. I need something like soft selection. But whenever I increase the fallof range of soft selection, it effects the upper stories which are in the range of fallof -naturally.
What I need is something extending the selection only through the path but act like soft selection.
Thanks a lot!
Hmm...
Edge Disstance does something else... How to use it actually?
Edge distance might work, but I think what you are looking for is more like Spline FFD.  This maxscript will allow you to select an edge loop, the applies a spline to that loop, with multiple control points specified by you, which allows you to manipulate the edge loop you selected with FFD-like control.  Take a look, and maybe it will be of use.
http://www.scriptspot.com/3ds-max/scripts/spline-ffd
Thanks a lot! I'll try and tell the result.
