Scripts: floor generator and material texture loader + color wall question
Hi.
1) Floor generator problem: I converted my floor to editable mesh, but the floor generator don't work cause it says that the base object need to be coplanar?
2) Material texturer loader 1.1. It just don't work or I don't know how to use it for Arnold renderer. I just need to apply textures to objects. Strange thing happened, I loaded one image and then tried to load another image but it did not work. Tried to reset to defaults but I was just hearing that windows "ouch" sound. 3Ds max worked.
All the plugins are there in 3Ds max, but they do not work or I don't know how to use them.
Bonus question: how to color a wall, but not completely? I.G. I want to leave straight line up white above to be realistic. Is there something like a wall generator script?
Thanks in advance!
Update: Coplanar objects are plane, rectangle. (and so more, I don't know what)
Still have to see what is with material texture loader, and then I'll come back.
And I still have a question regarding coloring a wall. Basically, I need to color a wall with one segment i.g. blue, and another one i.g. white. I'll play and see but any help is really appreciated!
Floor generator solved, color walls - there must be a trick, I'll find on the web, and material texture loader - weird, but my GPU can't support that big project I'm working on so I'll have to switch to Blender for now or to download earlier releases of 3Ds Max.
The problem is in GPU standard + default shading + viewport - it just don't look good and guess that's to the GPU? Maybe I could just apply materials to objects (cause basically, that's all that is left, apply light and sun and sky environment and render through CPU and it will be ok, cause I guess that viewport rendering use GPU?) 3Ds Max works pretty much smooth, though and I can do anything.  Facets work ok though?
But I have troubles when it comes to loading textures through material texture loader, and reallly don't know why.
Watched the YT show off, but I don't know what's the problem.
Hi Andrejee, try contacting the creator of the Material Texture Loader, he is glad to help out if any problems occurs with the Arnold workflow.
ahmadshab745
Community Visitor
Community Visitor
can u share how u solved the floor generator problem please ?
