scatter  custom shape on each polygon
erfan.azarin
erfan.azarin
Hello good time
I want to scatter a shape on each diamond shape polygons separately. How can I do that?
thanks for your reply
(I attached a photo)
oliver
If you want to display a texture on every polygon you can apply a UVW Map-modifier set to Face. Then apply a material with the desired texture.
If you want to position an object on every polygon I suggest using ParticleFlow.  Enter the polygon-count in the Birth-node and set the Position-node to Polygon.
erfan.azarin
Thanks for your detailed answer. I appreciate it
