ring selection does not work after bridging faces
mitviz
mitviz
i had a rectangle and i made a bridge at one section and deleted and faces i do not need and made sure to weld all vertices but the ring selection does not work after, its something that usually annoys me, why does this happen? here are some images to show, you can see the ring selection in the red area but it does not go around all the object, the other image shows the area that i bridged1.JPG2.JPG
Eznaex
Can't see properly on first image because gizmo is in the way. Make sure that you don't have any N - Gons or triangles in that area. you can check by going to polygon mode in edit poly then go to the ribbon - selection and click non- quads. Also try checking for overlapping verts. go to the + in viewport and select xview - overlapping vertices.
mitviz
you can see the ring selection in the images and no triangles and overlapping edges or faces
Eznaex
can you upload the file and ill take a look?
mitviz
o i found it! was overlapping edges for real, i didnt see i didnt update when i changed to xview, as simple as that
Eznaex
oh haha good 🙂 Just mark my answer as a solution so people know its solved.
