Reverse Extrude Problem
want to reverse extrude facewant to reverse extrude face
Hello All,  As you can see photo above I want to extrude face to back, but in this photo below side faces doesnt disappear
Then I decided to use move tool on face , i get it. But in this instance , i cant control axes properly as you can see photo below
THANKS SO MUCHH ALREADY
10DSpace
@Anonymous
When you do a negative extrusion like you are doing in the 2nd image, it is normal for the sides to be there.  You are extruding the polygon so Max is leaving the original Edges in place and making a copy of the edges to travel with the polygon negative extrusion.   If you do not want the sides just delete them after completing the extrusion.
Yes I have tried delete to,but it dont separate polygongs. It deletes whole face. 😞
10DSpace
@Anonymous
Sorry, in the case you are showing you will not be able to delete just the portion of the sides that you want.  You need to target weld each of the original vertices to the new location of the extruded polygon.  This will remove just the portion of the sides that you want.
Done ! 😄 Its all about vertexs. Thanks bro
