Problem with Extruding multiples splines
Message 1 of 8
Hello !
I have used splines and connected arcs and lines , and when I select them together to extrude them there is no face on the top and bottom.
Check the screenshot
Thanks you for your answers !
Replies (7)
Message 2 of 8
ads_czechoj
It looks like some of vertices are not welded. Make sure to weld all vertices before adding the Extrude modifier.
Message 3 of 8
I tried with different things and they are welded
Message 4 of 8
ads_czechoj
Can you please attach the 3ds max file with this shape?
Message 5 of 8
Richard.Vivanco
Draw over with a new line, enable snaps  toogle with only vertex to draw with precission.
Try again with the extrude modifier.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Message 6 of 8
Sure,It's not the original because my project can't load..
But I have still the same problem
Message 7 of 8
ads_czechoj
Thank you for your file. You cannot have a start and the end cap on not attached and welded shapes.
Steps to fix the issue:
(I included all steps on attached video)
1. Select any of the shapes, right click in the viewport to open the quad menu
2. From the quad menu chose: Convert to Editable Spline
3. Go to the quad menu again and choose: Attach
4. Attach all other shapes.
5. Select overlapping vertices on corners of connected shapes and weld them (use different values for the threshold if needed)
6. Now add the Extrude modifier.
Message 8 of 8
I thank you very much for what you have done for me and the help you have provided I could not ask for more thanks for taking the time to help me! it has been a pleasure I thank you!
