Object Naming For Export
I've tried to find a solution to this but haven't been able to so far - and not certain if I'm even searching correctly.
I've been working on a model and wanted to export it to DAZ. It comes out fine but the names I want for the parts aren't showing in DAZ.
Example:
I'm wondering if there's something I need to do in 3ds Max to get the parts names to come out the way I want - preferably without having to manually change the OBJ file - instead of that "wire_#########"? I've tried exporting with "Use Material" unchecked but DAZ just shows "Default" in the Surfaces tab.
I'd appreciate any help with this. Thanks in advance!
BDF
Fadhil_Farook
I just downloaded Daz, and realized, that the objects must be named by applying Materials to those objects within 3DS Max. As for having the name "Wire#######", it's because it doesn't have a material applied to it inside 3DS Max. And also make sure that you export a non primitive object. eg; Editable poly or Mesh. I exported two primitive objects such as "Line (renderable in 3DS Max)" and a Primitive "Box"
I am not a DAZ user but, this worked for me when I tested. See the attachment for a clear picture.
Worked like a charm! MANY THANKS!!! Smiley Happy
I've never messed with the materials in 3ds Max so never realized this had any effect outside of it.
BDF
