Morpher
Morpher
Morpher
Hi can anyone tell me why this has happened it's been fine with all the points i've created but this one goes off in all differrent directions that are not related to any of the models. Thanks in advanceScreenshot (6).png
Forgot to mention this is using the morpher modifier. I'm wondering if i accidently changed some settings?
paulneale
This would be caused by the target not having the same vertex order as the original.
Paul Neale
http://paulneale.com
Paul Neale
Thanks for you help. Just so i'm clear for the future was this because i edited the wrong one copied that part into the model i wanted to edit, kepping the same amount of vertex but changing the order?
Steve_Curley
Almost certainly, yes - that would be the cause. The only thing you can do with Morph Targets is manipulate the existing vertices. No adding, removing, converting to Mesh and back again, exporting/importing.... anything which is even remotely likely to alter the vertex order.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
