Announcements
Minimizing views and deleting Bipeds
I maximized the perspective viewport. After that i created a biped but some how it created 7 or 8 bipeds. However, i am seeing only one of them. Kindly guide me how to remove the previous bipeds and restore the screen such that i can view all the 4 viewports.
Zulfi.
Use Alt+W or the button in the bottom right of thescreen, to toggle between maximised viewport.
To delete a biped you only need select one object belonging to it, then press the Delete key.
If for any reason you can't see them, press H to select by name. Each biped object will have a prefix Bip00# with the number indicating which biped it belongs to.
Thanks. it worked. Bipeds were not visible so i pressed H and a window appeared and i selected the biped with its identifier and pressed OK. Then the window disappeared and when i pressed delete, it got removed.
Zulfi.
