Maxsript Rollout Handler Exception
I am problem so that InstantRig install for this is Maxscript error. Can you help me?
-- Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 316093; line: 8524
-- MAXScript Rollout Handler Exception:
-- Runtime error: Skin need to be selected and in the modifier panel Skin:Skin
-- MAXScript callstack:
-- thread data: threadID:3688
-- [stack level: 0]
-- In i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 307324; line: 8328
-- Defined in encrypted script
-- [stack level: 1]
-- called from FN_buildArm(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 316094; line: 8524
-- [stack level: 2]
-- called from i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 167375; line: 4339
-- [stack level: 3]
-- called from FN_build(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 168463; line: 4378
-- [stack level: 4]
-- called from i loop; filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 165778; line: 4276
-- [stack level: 5]
-- called from FN_build(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 165783; line: 4277
-- [stack level: 6]
-- called from FN_buildRoot(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 236309; line: 6464
-- [stack level: 7]
-- called from buildBtn.pressed(); filename: C:\Program Files\Autodesk\3ds Max 2018\scripts\iRig_1.52.mse; position: 456625; line: 11509
-- member of: Rollout:startupRoll
-- [stack level: 8]
-- called from top-level
Please answer me.
