Material cannot apply well
Good morning!!
I am applying materials and when I choose an image, and I apply to material, this is showed as lines. Can you help to solve this situation? At the same time, renders are too pitted.Image 1.png
Irshad_Shah_3dArtist
Hi Friend..
I think you make this shape with boolean.
So you need to unwrap this object or you can just apply uvw map and select box.
This will solve your problem.
Thank you.
