Making nice corners for floor moldings
jakoblindqvist8
Observer Observer
jakoblindqvist8
Observer
Observer
Hello! I have problem with my floor molding, I want to make this a nice corner were all the vertexs meet up. I can't seem to find any tool to make this happen so therefore I reach out here for help. All help is good help!
// Jakob
oliver
To avoid such situations I would use Splines to model this.
1. Draw two splines, profile and path.
Two paths: profile (blue) and path (pink).Two paths: profile (blue) and path (pink).
2. Assign Sweep-modifier to the path-object, switch to Use Custom Section and pick the profile-object.
Path object with Sweep-modifier applied.Path object with Sweep-modifier applied.
You may want to tick off Smooth Path in the Sweep-settings in order to get sharp corners.
