Main toolbar content missing
Hi.. I'm using 3ds Max 2018 for windows in windows 10.
I'm unable to see my toolbar icons. I had attached my max window screen short ..
Can you help me with it?
irishman_team_kilber
try clicking on customize menu show UI your main toolbar should be ticked/checked if it's not then check/tick it see if that helps
Hey Sourabh,
can you share further details about your problem, such as :
did the toolbar show before or it's been like this since the installation ?
Also, please try updating your graphics driver, which currently seems to be the problem.
If all else fails I can you to reset 3ds Max, which usually works in most cases.
My graphic drivers are up to date. And i had already reinstall 3ds max 2016 2 time but this problem is not going .
rendermaster
try
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
It worked..
Thank you so much..
rendermaster
@Anonymous wrote:
It worked..
Thank you so much..
You are welcome
