Inflated Mesh - breaks the sctructure
jackob_raczynski
jackob_raczynski
Problem: Downloaded model of Bed.
Austin (pcon-catalog.com)
Their model is not accurate to the actual pictures of the bed. Frame of the bed is inflated a little bit.
What i wanted to do, is to select the frame, apply "Cloth" and inflate it just a bit. But this process breaks the structure of the frame.
Question: Any idea how to make it more accurate and do not break the structure?
Thank all of you
Jakub
RobH2
Are you talking about inflating it like pumping air into it? Or, can you just scale it up a bit? If you can get by with just scaling it or manually painting verts to pull them out, you might get by just fine.
If inflating cloth, maybe check that the mesh it maifold, welded and has no errors. Inflating doesn't work well if there are holes in the mesh. Often purchased models are not perfectly modeled to be able to handle all the modifiers you can throw at it. I have to repair purchased meshes all the time so that they will behave the way I need them to. Use 'STL Check' until you get zero errors and I imagine it will inflate.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
