Ignore Backfacing Button Disappeared
5HARRJ73
5HARRJ73
Community Visitor
Community Visitor
In my 3ds max 2022 I went to go and click ignore backfacing and the button has disappeared. I am unsure if I misclicked a keybind that did this or what but I've been searching the internet for an hour trying to find a solution. Just wondering if there is another way to find this button or a way to make it come back. Maybe I just haven't noticed its disappearance since upgrading to 2022 until now.
BenBisares
Autodesk Support
Autodesk Support
It's there but integrated into a new function called "Optional Culling". You would enable "Backface" to get the equivalent of the "Ignore Backfacing" toggle.
Ben Bisares
But it doesn't work. When I press the backfacing button and select the back polygon on the geometry, only the front one is highlighted anyway, how to select a polygon inside my geometry?
BenBisares
Autodesk Support
Autodesk Support
"Ignore Backfacing" tells 3ds Max to not select any polys that are facing away from you so the behaviour you are seeing is correct.
I guess I would need to know your workflow in more detail but if you are trying to do something like work on the interior parts of a car but the roof, windows, etc. make it hard to select what you need I would do the following:
  • Select the outside polygons
  • Use the "Hide Selected" in the Edit Poly attributes
  • When done don't forget to click on "Unhide All"
Ben Bisares
abushova
Community Visitor
Community Visitor
Hi. Ignore backfacing isn't in Edit poly /Editable poly of 2022's 3ds max, but in Edit Mesh/Editable Mesh. I searched and found the information in Google .
I was able to use it in Edit /Editable Mesh.
