I have a question while unwrap!!
unwrap uvw During , drag the polygon and select it, but only the back side selected.....
10DSpace
@Anonymous
I want to know why only the backside is chosen!
It looks like the normals are reversed (i.e., pointing inward) on your model and therefore selecting from the front selects only the back side polygons because they are (incorrectly)facing toward you.   The selected polygons are highlighted with a dull red color.  When the polygons are facing correctly outward from the mesh surface they are highlighted in a bright red color.  To fix your issue,
1. Place Edit mesh modifier on the stack just below your Unwrap UV modifier,
2. Select all the polygons and click “Unify”. If they still are not bright red as shown here, click “Flip” and that should correct the normals.
Thank you! I was able to solve this problem simply!
