- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ok so,not sure if this goes here or not but ive been following a tutorial to make a gundam
this is the tutorial: http://www.tutorialshine.com/3ds-max-tutorials/modeling/52-gundam-rx-78-2-modeling-head
well i got up to step twenty on part 3, and i found i was unable to weld the vertices...so i tried using bridge and connect but i was unable to do that as well,when i clicked the command buttons,nothing happened! i clicked several times with no results. i closed the program and tried it again,nothing. then i tried using connect or bridge on another model and it didnt work wither...it was working fine the other day but now none of these commands work at all,the hell is going on? :<
my version is 3ds max 2013
