How to smooth this bottle?
Message 1 of 8
Hi, i have created a bottle, starting from a plane. Now in the attached IMAGE you can see that there are 2 errors.
How to fix this 2 errors?
I want a smooth and perfect shape
Replies (7)
Message 2 of 8
jackietsteh
Add a turbosmooth modifier?
Best regards,
Jackie Teh
Portfolio: http://www.coroflot.com/jackieteh
Youtube Channel:https://www.youtube.com/user/jackieteh
Message 3 of 8
yes, but the problem is not solved, I want to delete the 2 lines that you can seen in the attached IMAGE
Message 4 of 8
har1sf0x
Hello there,
  Could you please attach a photo showing the edges of the model?
Enjoy,
har1sf0x
Message 5 of 8
Irshad_Shah_3dArtist
Hi friend
Can you attach the model image with wireframe
Message 6 of 8
leeminardi
If the bottle is round you could start by creating a spline that defines one half of the silhouette of the bottle then move the pivot to where the centerline of the bottle should be.  You can then use the lathe modifier to make the 3D bottle.
At this point it is easy to edit the profile to make minor adjustments as well as the number of segment along the profile and around the bottle.
lee.minardi
Message 7 of 8
hi,
I got the same problem.I found a way to solve this problem. Select two edges and chamfer it.(Don't use more than 2 lines while chamfering and Make sure to keep a greater distance between two lines).Then Now use turbo smooth.
Message 8 of 8
bobopet
I had this same problem with a wrench I was modeling. Applied turbosmooth and some parts ended up rough.  I am pretty sure that you have some unwelded vertices and the program is confused how to smooth certain parts. Try welding them.I hope it helps.
