Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board.
How do you open the UV Editor?
Message 1 of 10
I come from a Maya/Houdini background and I'm learning 3ds Max. It's super simple I'm sure, but I can't figure it out.
I've imported a .obj & I'd like to see it's Uv's (I uv'd it in Maya) & textured in Substance Painter.
How can I view the UVs without re-uv mapping it?
When I do an Unwrap UVW Modifier, the UV view has no Uvs.
Replies (9)
Message 2 of 10
guido77
Did you open the UV editor within the Unwrap modifier?
[9b788fcc690e08a7edae25bd7341e4b7]_Image%202017-01-14%20at%2010.13.36%20AM.png[9b788fcc690e08a7edae25bd7341e4b7]_Image%202017-01-14%20at%2010.13.36%20AM.png
Message 3 of 10
Yes, but the UVs aren't there. Is there a magic button I'm missing?
Garrett Hoyos
*785-608-9356*
*VFX Artist*
garretthoyos.com
Message 4 of 10
Sometimes when I import something, the uv's are off the checkerboard/image and I have to zoom out with my mouse wheel to see them.
Message 5 of 10
ads_czechoj
Use the "Pack: Custom" option.
Message 6 of 10
Hey everyone.
I worked with Max for more than a decade, and I've brought up the UV editor the same way, (click Unwrap UVW, then open the UV editing window.)
Now I'm working in 2018, there must be a new way to bring up the UV editor that I'm missing.
When I click Unwrap UVW, (on an object with some UVs already applied,) the UVs reset.   But this seems to be the way to open the UV editing window.
Is there a new way to open the UV editing window without resetting the existing UVs?   Let me clarify with this  image.  The object in the viewport is already partially UV mapped, but now I'd like to map the rest of the object, SO...
Message 7 of 10
Message 8 of 10
I also came from Maya and had the same problem.
Here is what I find a way might solve it: in UV editor, it offers saving UV mapping to a file. So save correct UV and reload it later after you've done with other modifiers.
It works for me after I need to super-smooth the surface but have not tried in other cases.
Message 9 of 10
Hi there! Actually, the problem is solved now. Autodesk apparently found out about this issue, and fixed it. It wasn't a feature, it was a bug! 😉
If you check for an update, this issue should be fixed.
Thanks for the shout-out!
Message 10 of 10
rangikumotsumoto9
Community Visitor
Community Visitor
caballo
