How do I connect two vertices?
http://prntscr.com/ictzfo
I want to connect two edges/vertices together but I can't find the weld/connect or bridge commands under Edit Geometry. Can someone give me some advice? http://prntscr.com/ictzzn
miledrizk
Your object is an editable mesh not editable poly,
right click your object and do Convert to Editable Poly.
And by the way even in your editable mesh object you can still do Weld like
in picture 1
In picture 2 i converted to editable poly
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
