Hotkeys/Shortcut
Hotkeys/Shortcut
Hotkeys/Shortcut
Hello Guys!
So I've been working on my hotkeys/shortcuts since I'm recently doing heavy modeling all of the time and I was wondering, so you know when you extrude or bevel polygons there is that button called "Settings" which opens up Polygon Extrude control that is called "Caddy Control" ? I will post a photo of it anyway, the question is can you assign a hotkey for that? I tried "extrude settings" hotkey but it isn't opening up the caddy thing, any idea about this?
In the list there are two extrude polys. It is the first one of the two identical entries.
By the way also will appear with shift over the button
I still can't get it to work, tried everything from what you told me to trying the extrude settings in "Editable poly" hotkeys and still nothing, I don't know what's going on 😕
Have you tried both? It works here, you need to be in subobject mode vert, edge, border or face in order to work.
And it needs to be an editable poly or edit poly. Edit mesh or others won't work.
In the end somehow the "Extrude Settings" in "Editable Poly" hotkeys started working lol, thanks!
Cheers mate
