Hotkey Issue in 3DS Max 2020 (updated)
rsghosh
rsghosh
I'm recently facing some problems with hotkeys in 3DS Max 2020 latest updated version. Some(mainly 2 at the moment) default hotkeys not working and I have checked there is no other function added with the same shortcuts.
1. Ctrl+Shift+E = connect in Edit Poly and Editable Poly
2. Shift+X = Constrain to edges in Edit Poly and Editable Poly
All other default and customized hotkeys are working properly.
Please help to solve this problem.
rsghosh
Repeat Last Command is also not working which is " ; " and it is default.
Please tell me how to fix these.
BenBisares
Autodesk Support
Autodesk Support
These shortcuts remain the same in 2020. Did you try enabling the Keyboard Shortcut Override toggle?
Ben Bisares
rsghosh
Oops...I did not checked it ago. Now all shortcuts are working.
Thanks Ben.
BenBisares
Autodesk Support
Autodesk Support
Yeah it catches me out sometimes too. In any case, glad to hear things are working as expected on your end!
Ben Bisares
