Fixing Endpoints of an object
I have two spheres across from each other and I want to put a cylinder in between connecting the two spheres. Is there a way I can fix the ends of the cylinder to the centers of the spheres?
PROH
Hi. I think the easiest way is this:
1) First make sure that the pivot of both spheres are centered
2) Set the 3D snap to "pivot" and activate it
3) Draw a line from one pivot to the other pivot (with snap)
4) Make the line renderable, set it to "Round" and set the thickness to the diameter you would give the cylinder.
Hope it help
BTW - If you want to make the length of the cylinder/line vary (following the spheres), then use a "spring" instead of a line.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
