Face intersection selection, please help!
IOSIFSTALIN2015
IOSIFSTALIN2015
need-it.jpgHi!
1) I have 3 x 3 faces (or much more) deformed poly for example (tris and quads).
2) I have column (or a bunch of any poly in space) that intersect this plane in the
middle polygon (with no edge or vertex intersection) and sometimes with edges intersections at the same time
3) I need script (or working method) that can detect (and select) intersected polygons in base poly
Please help, very usefull!
CiroCardoso3v
You could try explore the Vol Select.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
IOSIFSTALIN2015
yes, but it wont work if intersection object intersects in ONLY ONE polygon in polygon center  (like in left example) without edge or vertex intersection, just one face in middle - center (
