- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone, i'm new to 3ds and today i set out trying to open a window through a wall.
I created a box resembling a wall, divided in 9 sections, then i selected the 2 central corresponding panels and i hit the bridge command. So far so good. Then i wanted to split the bridge poligons in multiple segments to simulate a double pane glass window and here's where I hit a wall.
No matter how angry I became at the bridge caddy, I have been unable to add any segments or to implement any changes from the caddy options. The values changed but i couldnt see any results in my model.
Then i tried to replicate the problem on a different bridge between two boxes and the same thing happened. I'm at a loss. I have spent way too many hours on this and I havent found any relevant post online, so I'm left thinking that I'm probably not seeing something entirely obvious.
I will be immensely grateful for any help. Below a screenshot of the issue.
