drag+shift to add segment in 3d max
Hi
usually, when I modeling I can choose the edge (in edit poly) and drag it while I'm holding the shift key to get segments
for some reason, it is not working anymore
can you please help me with this?
thank you
Fadhil_Farook
Can you upload a short video clip of this issue? Would be helpful to identify what exactly is happening. Also, make sure that under EDIT GEOMETRY > CONSTRAINTS - is set to NONE.
Also make sure your KEYBORD SHORTCUT OVERIDE TOGGLE is toggled/active if it already isn't (See attachment-1).
Irshad_Shah_3dArtist
Can you upload the image of model
