Custom Geometry in Create Panel
Hi there,
I was wondering if there is any way to add custom geometry to the Create Panel, for instance in this example I was wondering if there was a way to add a screw head to the panel, for easy access? If not are there any alternatives to this that anyone can think of?
Thanks in advance,
George
don_3259
hi dear george i think that is not possible in 3ds max but may be some script may be help for this.
thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
merge command under import, or you can drag'n' drop files from explorer/asset browser
can dig maxscripts to automate merge and place this script into a button
can dig maxscripts to automate merge, and place this script into a button
don_3259
hi swordslayer mate thanks for nice share.
Ali Sajjad
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
The script I use in my travels is the same one that @Swordslayer mentioned here.  Make sure to put the resulting .ms file into your root/Scripts/Startup folder.  If you are programmatically inclined you can also script a solution as a geometry plugin.
Best Regards,
