Create spline from intersecting meshes
truckexpert
Message 1 of 8
truckexpert
Is there a way to create a spline from intersecting meshes or polys? I have two intersecting meshes, and I want to create a spline at the intersection.
Thanks in advance.
Dave
Peace,
Dave
System Information:
3DS Max 2023 and 2024
Microsoft Windows 11 Pro
Dell Precision 5820
Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz, 3504 Mhz, 12 Core(s), 24 Logical Processor(s)
Display Adapter: NVIDIA RTX A4000
Adapter RAM (1,048,576) bytes
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.7 GB
Available Physical Memory 45.6 GB
Total Virtual Memory 81.7 GB
Available Virtual Memory 56.5 GB
Page File Space 18.0 GB
Replies (7)
Message 2 of 8
don_3259
when you do intersection then you get a path which is like the shape you want then make spline in top view by using that cut as guide....thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Message 3 of 8
truckexpert
Thank you, Ali, for taking the time to reply!
When you say "intersection", do you mean boolean, proboolean, or some other CREATE function?
I tried using create\ProBoolean\intersection+subtract and I got the shape you see attached. What I REALLY want to end up with is just the curvy spline on the top (RED arrow).
Also, why is ProBoolean creating some edges that are not at the intersection (yellow arrows)
Thanks again!
Dave
Peace,
Dave
System Information:
Dell Precision 5820
Message 4 of 8
don_3259
yes i am talking of boolean options use it...thanks
Ali Sajjad
Message 5 of 8
Swordslayer
If you use max 2017 with the new booleans, you can duplicate the boolean result and convert (yes, convert) directly to editable spline to get the intersection curve.
Message 6 of 8
truckexpert
Any chance you could show me how to do that? I've tried several methods using both Boolean compound objects to no avail.
Thanks!!
Peace,
Dave
System Information:
Dell Precision 5820
Message 8 of 8
truckexpert
Awesome! It worked!! Yeah!!! Thank you so much!!
Peace,
Dave
System Information:
Dell Precision 5820
