I have a set of polylines that I want to connect together into a mesh. Sort of like lofting, except there is no path. Just connect the cross sections together. The reference polys come from a pointcloud of a storage tank.
I need a mesh that closely follows the surface, so I started with a closed polyline (essentially circular in shape) at the base of the tank. Then, every few feet up the tank, I copied the previous polyline up to that level, then edited the verts so they were on the surface of the tank. (I did all this in AutoCAD). I now have a series of polys that go up the side of the tank. Because I copied and edited the starting poly over and over, the vertices for each poly start at the same place (3 o'clock) and contain the same number of verts ordered in the same direction. I assumed this could be easily connected together into a mesh, but I'm having trouble finding a command that does this.
Any ideas? Thx.
已解决! 转到解答。
