Connecting four vertices to make a face/quad...?
t_smith5
t_smith5
Is there a way of connecting four vertices together to make a face, like the ones I have selected in the image? In something like Blender, you would press F and it would fill the selected vertices/edges.
With 3 or 4 vertices selected, you can use the 'Cap Poly' command from the Modeling Ribbon. You could assin this to the 'F' Key.
With an arbitrary number of vertices, you will have to use 'Create' within the polygon subobject mode
Then subsequently click the vertices clockwise to form the polygon.
t_smith5
Thanks for the images and explanation. This is just what I need. 😄
