Coffered Ceiling build
D.Hudson1
D.Hudson1
Hello, I am using 3ds Max 2014, using splines and the Sweep modifier to make a coffered ceiling. I need the connections to be mitered and I can't figure out how to do that. Attaching an image of the ceiling moulding in process.
Thank you for any help!
rterry
With the presumption you are using a 'Custom Section' with your sweep modifier, How about instead of linear splines that are crossing each, rather create the boxes with the rectangle spline object and adding the sweep modifier but with "half" of the profile.
D.Hudson1
That is a thing of beauty! Thank you so much, rterry! Also, you guessed right, I did use the custom selection.
Cheers!
rterry
Thanks, Glad this helps.  Good luck!
