Announcements
Basic chamfer modifier won't work
garceau.dav
garceau.dav
Hi guys,
I'm following a tutorial and I do the exact same thing as the guy but my chamfer modifier don't work. If I go through the edit edges it works fine. It just plain do nothing. It's only this particular edge. I mean I select my edge then apply a chamfer modifier, it's supposed to be super easy... it works fine anywhere else. What I am doing wrong ?
10DSpace
@garceau.dav
Scroll down to the Filter By  section of the Chamfer modifier rollout and uncheck the Min. Angle Box.  The default value of 20 for minimum face angle is not allowing the chamfer to be applied to the particular edge you have selected which is on a perfectly flat surface.
garceau.dav
You're a hero, thanks for answering my noob problems.
CiroCardoso3v
If you want to chamfer that edge, you need to use the chamfer tool in the edit poly
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
