3ds maxdesign 2015 not showing display units correctly
3ds maxdesign 2015 not showing display units correctly  i kept system unit  meters and display units decimal inches but when i creating new object in not showing correct unit size.
rendermaster
what do you mean not "showing correct unit size." mind to have a snap shot
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
rendermaster
for info:
System vs. Display Units
It is important to note the distinction between System and Display units. Display units only affect how geometry is displayed in the viewports. System units determine the actual scale of geometry. For example, if you import a DXF file (unitless) containing a 1 x 1 x 1 Box, 3ds Max could import the box’s dimensions in inches or miles, depending on the System unit. This can have a significant impact on your scene, which is why it's important always to set up the system unit before you import or create geometry.
http://help.autodesk.com/view/3DSMAX/2018/ENU/?guid=GUID-69E92759-6CD9-4663-B993-635D081853D2
