3ds Max Reference Image Problem
Im having problem with 3ds Max 2018
When I import my Standard Shader with Image Plane , instead of having the photo in 1 single face
my Image Plane has thousands of Images in my Plane Primitives.
Thank you very much
Loocks like your material scale size wrong , open material map after :
don_3259
hi friend yes check all options of material carefully as another friend told ...... thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
bob.bernstein
Probably you are applying the image at "real world scale".  That default is on in the latest versions of max.  Just clear the check box for real world scale in the mat editor.
Can you please explain more about the photo you send.
Already found the solution , but thank you very much for your help...
I hope someone will find this thread helpful too.
Thank you very much for your response & effort to help us beginners in 3ds Max
