Announcements
3DS Max 2019 - Edit Poly - Select edge Loop function not working
peter.sherrill
Message 1 of 9
peter.sherrill
I am finally trying to upgrade to 2019 from 2016 due to some very great potential improvements to my modeling work flow. Even though there are a lot of improvements, some things seem to be very broken.
In 3DS Max 2019 - Within Edit Poly modifier - After selecting a single edge, and clicking the 'Loop' button, nothing happens
Ring is working properly
Replies (8)
Message 2 of 9
I can't reproduce it.
I suppose you are testing it in a regular geometry, for example generated by primitives (quad sphere etc)
Message 3 of 9
francesco.torchia
Hi @peter.sherrill,
I'm not able to reproduce it also.
I would suggest to reset 3ds Max user preference settings back to default and to install the latest update (3ds Max 2019 Update 1.1).
Francesco Torchia
Technical Support Specialist – M&E (3ds Max, Maya)
Message 4 of 9
peter.sherrill
Thank you for the replies. It is very strange.
Yes, I am trying to loop the edge selection within an Edit Poly modifier on top of a box primitive. The loop button has no effect. As I mentioned, the ring button works as expected.
I removed the ENU folder and tried again with the default settings. Still the same result.
Message 5 of 9
peter.sherrill
also. i am running the latest update 2019.1.1
Message 6 of 9
miledrizk
Can you create a small video screencast on how you're trying to do it?
Or maybe some clear screenshots
You can also upload the Max file so we can test it.
I personally use 3DS Max 2018, so you can do a save as 2018 in case you like to post the file.
It's also a good idea to post the 2019 version, maybe it's a version issue
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Message 7 of 9
peter.sherrill
rookie mistake. it is working. thank you for the input.
Message 8 of 9
miledrizk
Well good, it was finally solved!
But can you post what was the problem, this way the "Solved" check mark will be
More helpful for others in case they tried to check the post for solution.
miledrizk@gmail.com
Message 9 of 9
ahh i am facing the same problem can someone please guide me with it
