3d model to heightmap
I want to generate a Heightmap from a 3d model.
I tried to follow the thread: https://forums.autodesk.com/t5/3ds-max-modeling/3d-model-to-heightmap/m-p/4173377#M11097
But still couldn't get it right. Sorry I am a beginner with Max and need some help.
Please find the attached max file with the terrain. I need to change this terrain into a PNG heightmap.
Any help would be very much appreciated.
leeminardi
Essentially the technique that samab describes is to apply a gradient map to the terrain from the side as opposed to straight down onto the surface.   Thus the dark end of the gradient is at the terrains lows and the white at the highs.
Note, I collapsed the turbo smooth modifier before adding the UVW Map.  This may not be necessary but I like to start with a clean model.
I added a small box in the corner with a height that is approximately equal to the maximum minus the minimum elevation of the terrain.  I used it as a visual check on the change in the gradient. It was also helpful in checking the orientation (which way is up?) of the UVW map and gradient.   The box and the terrain have the same material. I used a Gradient Ramp map instead of a Gradient map to give me a little more control of the rate of change of the gradient. To tune the placement of the gradient you tweak the Gradient Ramp Parameters of the material and you can move the UVW gizmo up and down and change the width (which controls the height because the map is rotated 90°) of the planar gizmo.  Experiment a bit with these options until you get something you like.
lee.minardi
Hi Lee
Thanks so much for the help. It all makes sense now. Thanks.
The one thing I am still stuck with is I want to render this Height map out and use in Unreal Engine to generate a landscape.
Must I render from the front or Top view in Max? And what do I save the file as? I was told to save as .PNG, but there quite a few options under PNG save like optimized palette, 24, 48 bit.
Thanks again for your help, it is very much appreciated.
