What You Can Do with FBX Data in FME
Integrate FBX data for use in GIS with FME, writing out to formats like Shapefiles, Esri File Geodatabase, and KML. Once your workspace is set up, FME allows you to reuse workspaces over and over again, with the option to create batch translations.
Integrate Spatial Formats like GIS Data
Since FBX data models support mesh surfaces, spatial data such as TIN surfaces can be written to FBX using transformers like the TINGenerator and the SurfaceModeller. Create 3D models from GIS data to import into other diverse environments like Trimble SketchUp, Maya, or 3ds Max.
Use FBX Data in ArcGIS
Take your data straight into ArcGIS environments for GIS functionality by converting FBX to Esri File Geodatabase or to Shapefile format. Writing to Esri File Geodatabase also means that you can conserve the textures of your model.
Simplify FBX to an OBJ format
Convert your data to OBJ for a simpler file format if you only want the mesh without the additional feature supports like animation, lightmaps, or rigs. For example, this FBX file (650 KB) of 3D Vancouver buildings has been converted into an OBJ file that’s 240 KB smaller in an image adjacent.
Best Regards: Best Trail Camera Pro
1 Comment
Thanks you so much for sharing such a wonderful information.
