Updated Spacing tool
Spacing tool seems to be a legacy feature for me. It has some display bugs: every time I zoom in, or rotate the viewport, the result disappears from the model. So I have to update the sliders for them to appear again.
Also, It would be nice to come up with a dynamic solution for it, possibly as a modifier or a compound object, so the parameters of the spacing would be available, and the result could be modified later during the design. The same goes for Array function.
6 Comments
pokoy
Full support here, both tools could be made much more powerful with only little effort.
Another additional request would be to add a way in both the Spacing Tool and the Array Tool to be able to put, align (and attach) the result to another mesh object.
electrotoast_old
MartinBeh
Note that there are several other ideas along the same lines of improved Array tools.
It also has a serious limitation in which it doesnt keep the corect aligning of the distributed object along a spline. Pls upvote this fix here
[Spacing tool] Correct Z align when distributing copies along a spline
is this still needed now with the Array modifier?
shawnolson
Available in the Array Modifier.
